07-12-2016 07:12 AM
Did you try clicking the link in the post above yours?
07-13-2016 01:10 AM
Dear all, take a look at the recent updates related BACnet protocol in LabVIEW tools network
BACnet MS/TP Protocol for LabVIEW by Ovak Technologies
The BACnet MS/TP Protocol for LabVIEW is a set of VIs that enable NI equipment to work as slave devices in building control systems.
Implemented based on LabVIEW object-oriented programming, BACnet objects offer the advantages of code reuse, encapsulation, and maintenance. You can use the toolkit on NI real-time hardware targets such as CompactRIO, Single-Board RIO, and PXI. You can also use it on Windows-based computers.
Link: http://sine.ni.com/nips/cds/view/p/lang/en/nid/213120
BACnet/IP Protocol for LabVIEW by Ovak Technologies
The BACnet/IP protocol defines a standard way to communicate over a number of wires known as data link/physical layers. It also defines a standard way to communicate using UDP as a virtual link layer.
The BACnet/IP for LabVIEW toolkit is a library that you can use to browse BACnet devices, read and write properties, and perform other tasks specified in the BACnet standard.
01-24-2018 09:34 AM
Please find the video on below link for BACnet in LabVIEW
01-24-2018 09:37 AM
