05-26-2009 08:04 AM
Hi!
I'm trying to get some knowledge about how to call DLLs from Labview.
I have found a very nice example on this site:
http://zone.ni.com/devzone/cda/epd/p/id/1513
I have downloaded and extracted the file call_c_dll_in_lvnew.zip.
When trying to open the example file GenSortRandC.vi in the folder LabVIEW_code_and_DLL
I get the following error message.
"The procedure entry point RebootRTSystem could not be located in the dynamic library cvirte.dll"
I have searched the Internet and some forums but with no success so far.
Could you please let me know if you have the same problem whith the example?
I have the following setup:
- Labview 8.5.1 FDS (default installtion)
- Windows XP sp3
Mattias
Sweden
Solved! Go to Solution.
05-26-2009 08:09 AM
Hi Mattias,
i have no problem with this example. I can run it without an error.
Maybe it's because i have installed the CVI Run Time engine.
Mike
05-26-2009 08:34 AM
Thanks Mike!
I downloaded the CVI RunTime Engine and now everything works great.
Thank you for your time.
Mattias
