I have a DLL written in eMbedded VC++ 4.0 and it works well on my iPAQ when I called it from MS .NET Compact Framework.
Now I try to call it using LabVIEW PDA 7.1 module. But when I try to config the "Call Library Function Node". I got "Bad image. The application or dll is not a valid windows image. please check this against your installation diskette.".
I attached the dll and the VI. The function I called is defined as: long TDR3125_Open(void);
I think this information should help you out. If it doesn't, please attach a copy of the DLL you are trying to use (only the vi was attached to your last post).
Thanks, E.Lee Applications Engineer National Instruments
> against your installation diskette.".\
Could it be that your DLL is really a .Net assembly instead?
