12-04-2012 09:41 AM
I am making a wrapper DLL for SDK, that is utilizing a callback registration possibility. I have problems.
These are the function prototypes described in the .h file of the SDK.
One function is the Callabck prototype function.
Second, is the definition of the registering function.
Here they are:
typedef void (__cdecl * CmtCallbackFunction)(int32_t instance, int32_t callbackType, void* param, void* userParam);
XsensResultValue cmtRegisterCallback(const int32_t instance, CmtCallbackFunction func, CmtCallbackType type, void* userParam);
Using these function prototypes, I made callback routine:
void FireEvent( int instance, int CallBackType, void *param, void *UserEvent )
MgErr result;
//int *param1;
result = PostLVUserEvent( ( LVUserEventRef )UserEvent, param );
Sleep(0);
And callback registration code
XsensResultValue result;
//void *param = NULL;
CmtCallbackFunction FuncPtr = &FireEvent;
result = cmtRegisterCallback( instance, FuncPtr, CMT_CALLBACK_ONMESSAGERECEIVED, ( void* )UserEvent );
The whole function called from labview
int CreateInstance2( const char *SerialNumber, LVUserEventRef UserEvent )
int instance = -1;
instance = cmtCreateInstance( SerialNumber );
if( instance != -1 )
Sleep(0);
return instance;
In labview, I create the UserEvent, pass it to the library, register the userevent in wait structure.
When debugging the DLL, the FireEvent routine gets called, obviously, the PostLVUserEvent results in Error of argument.
The Event refnum is wrong.
I do not know how to pass the refnum to the routine. I thought, that it gets passed through the UserEvent parameter, but it does not 😞
Please help.
12-04-2012 10:43 AM
So the correct way to register was like this :
result = cmtRegisterCallback( instance, FuncPtr, CMT_CALLBACK_ONMESSAGERECEIVED, ( void* )*UserEvent );
I had there a missing asterisk.
12-29-2012 09:13 PM
Do you resolve it ?
I have meet the same question.I want to use call back with dll in labview.My question as below
http://forums.ni.com/t5/LabVIEW/Question-about-timeSetEvent/m-p/2266246#M717433
