09-05-2006 09:10 AM
DWORD
_MPUSBRead(void* handle,void* pData,DWORD dwLen,DWORD* pLength,DWORD dwMilliseconds);(PS-this method,from DLL, is called from my own method)
where the data read from the buffer is written to pData parameter. My doubt is: Should I create a DLL wich would have the method wich calls the _MPUSBRead? Or should I call the DLL with Call Library Function Node and everything else done in my own method I should do by "blocks". This is, creating every parameter that I send throw the _MPUSBRead method?
09-05-2006 02:24 PM
In other hand, I'm also working tying the calculator.vi. In the File>>VI Properties>>Documentation says that the .DLL file should be in the same directory of the vi (wich is). And should be assembly in Tools >> Advanced >> .NET Assembly References. But there is nothing like .Net Assembly Refecerences. I'm using LV8.0. There is only:
Mass compile; Edit Error Codes;Edit Pallete Set; Export Strings and Import strings.
09-12-2006 03:26 AM
09-12-2006 03:38 AM
Thank you jp_Braud.
Best regards.
