08-27-2013 08:57 AM
I try to call a function using CLFN. My problem is the parameters of the function I try to access.
Here is the function and his parameters:
typedef struct _BAR_INFO { ULONG dwSize; ULONG dwFlag; }BAR_INFO, PBAR_INFO; typedef struct _DEVICE_INFO { ULONG dwBarNum; BAR_INFO BarInfo[6]; }DEVICE_INFO, *PDEVICE_INFO; DLLIMPORT int GetDeviceInfo( unsigned int devID, PDEVICE_INFO pdevinfo ) { ULONG i; if(devID >= DevNum) return PCICORE_DEVICE_NO_FOUND; if(DevTable[devID].DevHandle == NULL) return PCICORE_DEVICE_NO_INITIALIZE; if(pdevinfo == NULL) return PCICORE_INVALID_PARAMETER; pdevinfo->dwBarNum = DevTable[devID].DevInfo.dwBarNum; for(i = 0; i < pdevinfo->dwBarNum; i++) { pdevinfo->BarInfo[i].dwFlag = DevTable[devID].DevInfo.BarInfo[i].dwFlag; pdevinfo->BarInfo[i].dwSize = DevTable[devID].DevInfo.BarInfo[i].dwSize; } return PCICORE_SUCCESS; }
In attached file there is the Get Device Info.vi that try to access this function. The code crashes when the function is called.
I probably don't pass the data parameters correctly to the CLFN.
Thanks for your lights §
Solved! Go to Solution.
08-27-2013 08:58 AM
The VI attached
08-27-2013 11:56 AM
A fixed-size array in C is equivalent to a LabVIEW cluster containing the same number of identical elements, so you need to replace the array with a cluster. Also, structs are always passed by reference and the C function expects a pointer to a struct, so you don't need to unbundle. Pass the cluster directly to the function as a single parameter. Try the attached revised version of your VI.
08-28-2013 06:48 AM
Thanks Nathan. Its working fine.
