02-06-2013 03:36 PM
I got one more question! Hope I'm not being tedious. Why can't I import other .lvm files to this VI? There seems to be no option to do that.
02-06-2013 03:41 PM
Abraham_E,
As I mentioned in the last lines of my previous post, I read the file one time and displayed the data in the indicators. Since I only had one data set, rather than re-reading the file each time I wanted to try something, I made the data default, removed the file read, and changed the indicator to a control.
All you need to do is put the File Read VI back in the program and disconnect the all rows control. Wire the data in its place and you should be able to use your other files. You might need to manipulate the file format if you use an Express VI.
Lynn
02-06-2013 03:56 PM
You are right. Maybe I was too anxious to try it out. I can now import .lvm files to your VI.
Thanks once again.
