09-08-2014 09:13 AM
I am trying to work with CVS-1457RT with my FPGA kit. CVS and the gige camera is showing in the MAX,but when I try to add the "Target" in the project I cannot find it. I also tried by putting the ipaddress but couldnt find or add the device. I am failry new in the FPGA and CVS field , please let me know if there are differnet settings I need to configure to add the CVS in my project.
09-09-2014 03:34 PM
Hi AnkitG,
Have you checked out the 145RT Getting Started Guide: http://www.ni.com/pdf/manuals/374216b.pdf? It is a great place to start.
09-10-2014 07:03 AM
Hi Rahul,
Thank you, After going through the guide I am able to get few things done. I do have one more query, I am getting Visa Error in MAX in remote systems menu and also my gige vision camera is showing as Network devices rather then IMAQdx device. Attached is the screenshot can you tell me if thats a problem and how to solve this.
thanks
09-12-2014 12:03 PM
Hello AnkitG,
Did you install IMAQdx onto the CVS? It should see the camera as an IMAQdx device if that driver is installed on the CVS itself. You can double check this by openning the software tab under the CVS.
09-12-2014 12:12 PM
@National_Burritos wrote:
Hello AnkitG,
I did install IMAQdx, software under cvs says " Ni-IMAQdx 14.0.0 installed with Gige Vision camera suuport. Now I am not facing any problem with that as I can run my program(display continous images) on the laptop and also can see image also on MAX(using Grab) I can see the camera working.
Next step for me is to use that display image program as a standalone application on CVS and I am not sure how to do that and will camera not showing under Imaqdx be create any problem.
thanks
