CRC-CCITT
Hi Toro,
just to give you a chance for a rating.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 11 of 17
(4,373 Views)
Following is a list of the most used CRC polynomials
· CRC-12: X^12+X^11+X^3+X^2+X+1
· CRC-16: X^16+X^15+X^2+1
· CRC-CCITT: X^16+X^12+X^5+1
· CRC-32: X^32+X^26+X^23+X^22+X^16+X^12+X^11+X^10+X^8+X^7+X^5+X^4+X^2+X+1
The ModusBus that I have is using the CRC-16 listed above.
Message 12 of 17
(4,817 Views)
The CCITT CRC-16 is the one used in Europe where as my version is the one usually used in the US
In your attached VI, if you use the followinfg settings
For CRC-16
set poly= 8005
and Set
Precond T
LSB First T
Reverse CRC T
others F
Then you get the same answer of my attached vi
hope this explains it
Message 13 of 17
(4,373 Views)
Hi Dr. Imad,
I have seen that I must set Precond to TRUE but I thought all others will be FALSE. In your VI you use the polynom in inverse sequence (0xA001 is backward reading of 0x8005). In this case it makes sense to set the reversing flags to TRUE.
Although LSB First and Reverse CRC are independent I have seen no case in which they have different states. I think this comes from the HW implementation of CRC calculation.
Wouldn't it be interesting to use the RIO card as a 48 (24 with handshaking) full duplex serial channel card with integrated CRC calculation and checking? You only need something like the MAX232 converters to get from TTL to RS232 and vice versa.
W
aldemar
Waldemar
Message 14 of 17
(4,373 Views)
I've been trying to use this VI for an application. It doesn't seem to give the correct results. The inner loop has eight iterations, suggesting this is done bytewise. This goes against the mathematical definition of CRC-CCITT. It also seems pointless to use a 16 bit polynomial for an 8 bit message.
Message 15 of 17
(3,443 Views)
Dr._Imad,
Do you have the VI, to send a String to a MODBUS RTU microporcessor and get response back, using your CRC-16 calculator?
thank you
Message 16 of 17
(1,742 Views)
Merci bien, j'ai pu résoudre mon problème de calcul de CRC qui correspndait pas au CRC obtenu avec la fonction crc_ccitt_ffff de excel
Il fallait juste modifier 0x0 en 0xFFFF en entrée
Message 17 of 17
(415 Views)
