COMPILE SUBPANEL
How would one go about compiling a subpanel vi that uses other vi's?
(2,825 Views)
Try looking under the examples that ship with LV.  This is under the help menu item in LV.  You can type in subpanel and find examples that might help you.  If you still have questions we can make and example for you.  Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,817 Views)
Thank you, but yes I know how to use them. What I am asking is once written, is it possible to comile the vi? I've tried
including the support files in the build script and it comiles fine but, the executable does not bring up the called vi's.
(2,815 Views)
Can you post your code?  it could be a path issue when building an exe.
BJD1613
Philips Respironics
(2,806 Views)
The problem is probably the path to the VI, like BJD said.
When you build a VI into an exe, the exe serves as a directory. This means if you want to get the directory for the EXE you need to do another strip. You can find out if you're in an EXE by using the Application>>Kind property.
I think this is the third time I wrote this today.
___________________
Try to take over the world!
(2,802 Views)
thanks tst,  I couldn't of stated it any better.  🙂  This is such a common problem.
BJD1613
Philips Respironics
(2,799 Views)
Actually, I meant that literally (unfortunately). Smiley Mad
And it was the fourth (at least): 1, 2, 3.
___________________
(2,791 Views)
