06-20-2015 06:19 AM
Hi , im using labview 2014 , and i'd like to initialize an srial communication , i built an vi , using VISA , but i cant choose my com port .
I dont have an COM port on my pc , im using USB to COM converter , it works great with arduino and HyperTerminal . I tried to check the Measurement and Automation , and i found that my COM port is not recognized there.
What should i do ?
thank you in advance .
06-20-2015 10:41 AM
Hi Cobmetal
If you are using Arduino before you may leave your serial port busy, so LabVIEW does not recognize . Try resetting your port.
06-20-2015 10:55 AM
What chipset is in the converter?
I've seen this type of problem with si labs needing to be installed multiple times because of enumeration conflicts.
06-20-2015 11:23 AM
06-20-2015 12:24 PM
And, Now that I think of it, Do you have the power mananger option turned off so Windows does not shut off the USB Port?
06-20-2015 02:33 PM - edited 06-20-2015 02:41 PM
Thank you guys , i've just found out , the NI-VISA wasn't installed ,
install it fixed the problem.
Thank you again.
