CFP ".iak" file problem
Hi All,
In my project I am using CFP hardware. I have kept ".iak" file in support files folder, which has all required files for project.
I call "FP open.vi", give path of ".iak" file. I have made installer referring to following link.
Link
Now the problem is , when I install the tool on other PC (Non LabVIEW or With LabVIEW), when I run exe, it asks for ".iak" file. Though I have taken all necessary steps mentioned in above link.
Can you tell me if I am missing anything? Or  is there other solution to this problem?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,217 Views)
No suggestions?... Smiley Surprised
Gaurav k
CLD Certified !!!!!
(2,190 Views)
I understand that you have included the .iak file in the 'Always included' (Dynamic files in the older version of LV) files of your application builder.
I would suggest you post the error screen shot and that of the vi where you are loading the '.iak' file. It may of help in identifying the problem.
Regards
Freelance_LV
TestAutomation Consultant
(2,185 Views)
Accepted by topic author Gak
Sorry for very late reply.
http://digital.ni.com/public.nsf/allkb/B0567407397065F586256BE30063F302 this link helped me in solving my issue.
Thanks to NI application engineer
Gaurav k
CLD Certified !!!!!
(2,153 Views)
