01-19-2016 04:49 AM - edited 01-19-2016 04:51 AM
Do you know what level of CANopen you need?
If you only need to look for some TPDO and do a little NMT to get the sensor up and running, then you should be able to implement that in LabVIEW.
Of course you need to know a little about CAN and CANopen messages, that you need to do anyway.
And for that you could just use a NI USB CAN module. (That is what I'm doing)
And CANopen is "just" a protocol on a CAN network.
Any module that can read a CAN bus can handle CANopen or any other CAN protocol.
01-19-2016 04:58 AM - edited 01-19-2016 04:59 AM
I did wonder why I would need any extra hardware for CANopen besides any CANbus hardware.
But NI have a designated CANopen module for the cRIO so I am not sure how that physically differs from their CAN module. I assumed there was something being implemented in hardware or there was a certain type of CAN used for CANopen (I know there is fast and slow CAN and I think some other characteristics that can vary as well).
I think the USB-CAN intreface is really cheap so unless there is a module that costs less then it should be ok I think. I wonder why they have a CANopen specific module if all of the CANopen elements are implemented in software. The other issue is whether any of the CAN modules would be compatable with a cDAQ.
I am not sure regarding the level of CANopen, I don't actually know what TPDO and NMT is so I guess I will have to do some reading. I don't fully understand what data I will be pulling out of the sensor or if there is a specific subsection of the CANopen data I need. I knew absolutely nothing about CAN until a few days ago so its all very new to me but I will try wrap my head around it. I am slowly getting there
01-19-2016 07:37 AM
01-19-2016 10:56 AM
Anyone have any idea what I do with the .EDS file?
01-19-2016
11:18 AM
- last edited on
12-09-2021
04:06 PM
by
NI_Community_Su
Hi David,
read it using any text editor you like!?
They just contain a list of CANopen objects. I'm sure I mentioned that before…
01-20-2016 03:19 AM
Sorry I meant what do I use it for in my application? As in does the LabVIEW code need to read it?
