09-17-2014 01:35 PM
I have a chassis with 3 CAN boards-NI 9286. Right now, I am trying to setup the CAN communication in Veristand. In Veristand, I have manually added a XNET CAN port, a .dbc file and a blank FPGA target bitfile in 986x Support.
But when I deployed the project, I received the following error:
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -61200 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW FPGA: The operation could not be performed because the FPGA is busy operating in FPGA Interface C API mode. Stop all activities on the FPGA before requesting this operation.
Does anyone know how to stop all activities on the FPGA?
Thanks.
09-17-2014 02:00 PM
09-17-2014 02:05 PM
Hi GerdW,
I was following the procedure '4. Configure the NI VeriStand Engine and Project with NI-XNET' in http://www.ni.com/tutorial/14706/en/. Right now, I am trying to get the CAN communication work. Will the blank FPGA bitfile be the problem?
I am using a cRIO-9082 with 3 NI 9862, 1 NI 9205 and 3 NI9401.
Thanks.
Jian
09-17-2014 03:03 PM
So you have made the LabVIEW project as described ?
And build a bit file, NOT deployed, in that project based on a vi added under the FPGA ?
Show us your project and what you have done.
