06-20-2008 02:56 PM
06-23-2008 10:24 PM
Hey Mtini,
For more information about point to point analysis please refer to Frequently Asked Questions about Point-by-Point Analysis and Point-By-Point Analysis.
The Point By Point VIs are usually used to conveniently and efficiently process data a point at a time.
As part 2 of your question, you'll need to either provide some screen shots or the VI's itself.
Hopefully this helps!!
09-18-2013 01:09 PM
Good afternoon. I wonder how to implement a low pass filter on my system. Which icon to use and where to put. Thank you.
09-18-2013 04:28 PM
Please start a new thread rather than appending your question to a 5-year-old thread.
You will get more helpful answers if you provide specific information about your requirements: Frequency range of desired signal and any interferring signals, sampling rate, does the data come in continuously or in batches? What generates the signal? How many samples at a time? Specifications of the filter - type, cutoff frequency, passband ripple, stopband attenuation, and so on. What wil you be doing with the data after it is filtered?
Lynn
09-18-2013 11:31 PM
I have a plate and Arduimu through this plate has data accelerations and angular velocities. So this board is engaged in a car, and the car will transmit noise to plate through vibrations. My goal is to reduce. My thought using low pass filter to cut high frequencies.
09-19-2013 02:32 PM
The Filter ExpressVI can easily be configured for a low pass filter. Theres a link to the help documentation below.
http://zone.ni.com/reference/en-XX/help/371361J-01/lvexpress/signal_filter/
09-19-2013 05:46 PM - edited 09-19-2013 05:48 PM
How can I put the icon of the low pass filter in my schedule below. Where do I fit in, for example on the block roll, pitch and yaw. So I view the graph with the input signal and then another graph with filtered signal.
09-20-2013 02:39 PM
It looks like your datatype is double rather than array. The Filter Express VI is designed to accept an array of data. Therefore, you will need to use some sort of point by point filter. There is a great example on the example finder. Go to Help>>Find Examples. Then select Analyzing and Processing Signals>>Signal Processing>> PtByPt and Array Based Filter.
09-20-2013 09:56 PM
I'm trying to put this filter in my VI but not getting to. The error in Labview programming.
09-23-2013 08:05 AM
Which filter did you use and how are you implementing it in your program? What error number and message are you receiving?
