ButterWorth Filter FPGA d'ont work with Cuttoff frequency less then 50mHz !!!
What about IIR filter which work perfectly  ! how can i use it in FPGA i'am looking for solution here ! if you understand what do you sugess !!
Message 11 of 21
(1,124 Views)
Someone from NI may need to join in on this message thread and comment.  I looked at that Express VI.  Interesting thing is that I can't do Altenbach's recommendation of looking into the Express VI.  It seems to have a different shortcut menu than other Express VI's and I can't do an Open Front Panel to turn it into regular LabVIEW Vi's to poke around in.
I think he has a point about the scaling factor between those numbers.  I tried entering 50 mHz in the Express VI and saw that the sample graph went empty.  I decreased the sampling rate to 5 KHz.and the line came back.  Than decreased the filter to 5 mHz and it went away again.  It seems that the ratio of sampling rate to frequence has to be about 145,000:1 or smaller (based on a few data points I checked) for the line to show up in the Express VI.  Probably a limitation built into the express vi so that it can work on the FPGA.
Message 12 of 21
(1,106 Views)
OK, I have to ask, your frequency band is 2 milliHertz to 10 milliHertz. Is this correct milli (10^-3)? Or do you mean MegaHertz (10^6) or kilo (10^3).
You won't be able to sample much at mHz freqs but MHz is more realistic physical value.
Rich J
Message 13 of 21
(1,095 Views)
mHz means (10e-3)  physicaly i want to have big constant filter Taux.
Message 14 of 21
(1,087 Views)
Tau - time constant. T=RC=1/2pi*fc = at 50mHz makes tau a big big number. OK.
Message 15 of 21
(1,069 Views)
No Sorry . is not enough for my physicaly system.
i wana to have Tau=10s;50s;150s
Message 16 of 21
(1,060 Views)
Then you will need to lower your sampling rate.
At 1 kHz, 150 seconds is 150,000 samples.  That seems like a lot of data for an FPGA to handle.
Message 17 of 21
(1,058 Views)
someone can explain Why when i put
cutooffrequency = 50mHz
sample rate = 50k S/s  physicaly i obtain Cutoff frequency = 0.11Hz  !!!!!!!! when i wana to lower physically cutof frequency what should i do ?!!!
i don't understand anything with butterworth filtre configuration. thanks for help.
Message 18 of 21
(1,044 Views)
I think some of the early comments about posting your code would be good!  Let us take a crack at it!
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
Message 19 of 21
(1,005 Views)
the code its very simple, its enough to use filtre butterworth bloc in the "FPGA math" library of labview. with PXI7841R. the code contain 2 loops :
1**the First loop (loopSCTL) to generate square signal.
2** the second its to do the task of filtration and see the filtred signal.
as its mentionned in the figure linked here.
Message 20 of 21
(994 Views)
