05-15-2012 05:58 AM
Hi all
I have a vi which reads from a file and manipulates the data using for loop. I am taking each element and multiplying it with a constant and converting it to I32. I would like to build back to a new array with the new values. I have attached the vi and a sample data file to read from.
Please suggest if there are any better ways to do this.
Thank you.
05-15-2012 06:06 AM
You can multiply the array with the constant and use the array instead of multiplying it with each element.
05-15-2012 06:14 AM
Hi Anand
Thanks again...I never thought numeric would work on arrays as well..
05-15-2012 06:18 AM
But what is the way to convert each element into I32..???
05-15-2012 06:47 AM
05-15-2012 06:48 AM
