02-07-2008 10:49 AM
02-11-2008 11:28 AM
02-11-2008 12:05 PM
03-17-2008 04:22 AM
02-05-2015 03:04 AM
Hi DJC,
Can i generate a good Gaussian beam using SLM ? I have a 633 nm laser but it is not GB.
I am very new in Labview code.
Nirmal
02-05-2015 07:18 AM
I have done something similar using a TI DLP kit maybe 8 years ago using LabVIEW. I used a lens to image the DLP so that I didn't have to work in the Fourier space. I don't know how much you know about your project but one concern is the discrete nature of the micro-mirrors will create a diffraction pattern of several orders. You will have to pick one of the orders.
As far as I can tell, there is no issue with LabVIEW. It is more the optical configuration of your setup that will be an issue.
02-05-2015 08:58 AM
Thanks Marc.
I create a phase mask of gaussian beam and send it to SLM. But in this case i consider that our laser is flat. i am using GS algorithm.
can i create blazed gratting pattern and send it to SLM for generating GB ?
Nirmal
02-05-2015 09:18 AM
Sorry, it is definitely not a LabVIEW issue here. I don't know much about what you are trying to do. I suppose that it all depend on how much gaussian you want your beam to be. It will not be perfectly gaussian because you have to take into account the pattern created by the discrete micro-mirrors.
03-23-2016 06:15 PM
Hello DJC11
Did you get it? I have the same situation.
Best regards.
Fano
03-23-2016 06:21 PM
DJC last logged into the Forum in 2008. You may get more useful information by starting a new thread and being as specific as possible about what you want to do, what you have tried, and what did or did not work.
Lynn
