I am new to labview. I need to make a project that can send/receive CAN messages. Using the NI-9862 module with the 9082 chassis. I finally got MAX and project explorer to detech the 9862 module. As far as the programming I need to do this...I'm not having any luck.
I pulled up the NI-XNET CAN CompactRIO.lvproj and in the "how to use this example.txt" it says to change the chassis to the one I am using. How do I go about this? In the example the chassis is a cRIO-9116, I have a 9082.
