Build a exe file with niimaqdx.dll
Hello, I want toask about how could I build up a exe file with    niimaqdx.dll    nivissvc.dll    nivision.dll
because when I copy the package including application & installer to the PC without LabVIEW,
after open the application, the causion jumps out and mentions about there are no those dll file, how could I fix this problem?
I tried to check those options like the first picture
but  it seems that  I have to select source...
Does anyone know about this?
thanks!
(3,930 Views)
Accepted by topic author mei0512
-Assuming you have taken proper licensing options: http://digital.ni.com/public.nsf/allkb/F1699570F78FECBB86256B5200665134
-You can Manually Transfer or Download the Vision Run-Time Engine, NI-IMAQdx, and NI-IMAQ to Target Machine: http://www.ni.com/tutorial/12530/en/#toc6
uday
(3,920 Views)
