NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Henrik1972
Accepted Solution
Build Specification does not include all files for my VI.
Hi!
As a part of a semester project i have build a VI to control a filtration unit. The VI is working fine on my computer, but I graduate next month and I have to deliver the files on to a person on the university. The problem is that even though i use the "Build Specification" function (i use LabView 2011 Professional Development System), files are still missing when the program is started on the new computer. A warning in the project file indicates that files are missing or removed to a different location. A file named pid.lib is not found, and it seems like the path to each file is the same as on my computer, but the build specification doesn't change that to fit the new computer.
I am a LabView newbe, and I have searced this forum and help files to try to solve this by my self, but now my time is becoming limited. Can anyone help me with this?
Henrik jepsen
Masterstudent Chemical Enginnering
Denmark
Trusted Enthusiast
TiTou
Re: Build Specification does not include all files for my VI.
The computer on which you're going to run your VI needs the LabVIEW 2011 RTE (run time engine), it is free and you cyn download it form NI website, just use the search.
And if you use LabVIEW toolkits in your application, they may require additional RTE, I'm not too sure about the PID Toolkit...
What I suggest is that you also use a build specification to create an installer, when you do so, by default it includes the installers your app will require (LabVIEW RTE and also additional toolkit installers).
Hope this helps
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Member
Henrik1972
Hi TiTou!
Thanks for your reply. The computer I have to transfer my files to has the same LabView version installed as I have. Shouldn't that solve the problem with the run time engine?
Henrik
Trusted Enthusiast
TiTou
[ Edited ]
It will only if that computer also has all the additional toolkits you're using in your app are also installed. Check that the PID toolkit is installed ont both.
Cervantes
Active Participant
A.Rohde
Hi Henrik
You can see what versions of LabVIEW and which Toolkits is installed in Measurement and Automation Explorer (MAX). If you Open MAX, and Select "My System" --> "Software in the left menu, then you can see all software installed.
If you click on the LabVIEW installation. In this case LabVIEW 2011, you can see all toolkits installed.
When you run a LabVIEW project / application on another PC, LabVIEW will use a defined priority of where to load the files from. This is specified in Tools --> Options --> Path --> VI Search Path.
So LabVIEW will frist try to find the VI/VI library in the folder of your project and if the VI is not located there it will look for it as a build function in the vilib, userlib or instrlib folders of LabVIEW. These folders contains VI's and VI libraries installed with LabVIEW.
In this case, as mentioned above you properly don't have the same toolkits installed on both machines. Therefore the PID.lib is not found in the vilib folder as it should be, and thereby you get the error. You can confirm this by reviewing the installed modules as mentioned above.
Best Regards
Anders Rohde
National Instruments Denmark
Member
Henrik1972
Hi Anders!
I will check the installes toolkits on the reciever PC. Somehow I had the comprehension that building an application in LabView would make it possible to use the program on another computer without having to install the complete package of LabView and the toolkits. I tried to build an application to a PC with the correct run time engine installed. It was possible to open the vi, but data acquisition and control inputs did not work. Do you have a beginners guide to vi export? I probably can't figure out which check marks to choose (which files to include and exclude) and why I have to choose that.
Henrik
Active Participant
A.Rohde
Hi Henrik
I'm sorry I think I misunderstood you. You wrote something about a warning in the project, and you shouldn't have a project if you build an application. You also wrote that it was possible to "open the vi" again on you other computer you should only distribute the built application (exe file, alias file, data folder and ini file), there should be no vi files in this. Are you refering to the exe file in the above parts?
It is possible to run the application without having LabVIEW and all toolkits installed, but you will still need to install the drivers (for data-acquisition that is NI-DAQmx) and the Run-Time Engine with the same version as the LabVIEW version that built the application. Some toolkits also have a seperate Run-Time Engine but the PID does not. The error might come if you try to open the VI files instead of the exe files, because then you would need to have the PID toolkit since the functions are not compiled into the exe file.
The easiest way to distribute you application is to first go into built specification and build an "Application (exe)", after this you can again in the build specification select "Installer", in the installer you include the built application and under additional installers you can choose LabVIEW Run-Time Engine, NI-DAQmx, and other things you application depends on.
Best Regards
Anders Rohde
Member
Henrik1972
Hi Anders and TiTou!
I found a problem with the definition of names of my DAQ-6009 USB devices (I have two). Somehow the name Dev-1 switched place with Dev-2 during export of the projectfiles (I used Source Distribution). That was the reason for the missing respons from the program. A rename in "Measurement & Automation" of the hardware solved the problem. Why this name confusion occured is a mystery to me. But the main issue is: It works now.
Henrik
Trusted Enthusiast
TiTou
[ Edited ]
Ok, well this is a interesting issue! :smileyvery-happy:
Is there mode we can do to help? I'm sorry I won't be able to explain the swap name mistery...
Cervantes
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
