09-24-2012 02:52 PM
This is the error I see. Build was unsuccessful
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
I upgraded to LV 2012 recently. I was able to build exes until today when I tried including ALL OTHER VI's and SUBVI's in "Always Included" section of source file settings and only MAIN.vi in Startup vis. I am not able to proceed. Please suggest tricks
09-24-2012 05:13 PM
I have had random errors before building. Check the obvious like you have space available on your hard drive. Other option is to exit LabVIEW, reopen, and try again to build your project. Lastly, try pressing "Preview" in the build options to see if it indicates any issues / errors.
09-24-2012 05:18 PM
The weird thing is when in development environment, everything works. When I choose preview, it builds too. But, when I actually build, I get the error.
I removed the folder and added it back again. Main thing I did is move one of the library (LLB) into program files user.llb folder ratherr than have it in my application, and have LV load the llb from there. That seemed to have solved the problem.
09-25-2012 11:00 AM
Have you tried to mass compile all the VIs from the project?
