Build Array
Looks like you want to get the data column that has IRAD in the header. Two "delete from array" in a row seems a bit of overkill. SImply use "index array" to get the desired column.
(Since we don't have your file, please run your VI once, then change the indicator named "array" to a constant (right-click terminal, change to constant. Now delete all the file IO part and save the VI under a new name. Attach it.)
Message 31 of 46
(777 Views)
hi i need help on this.I am doing programming on using the solar energy data i got and then plot the graph for the solar energy. I got data for the array part but i cannot get the data for IRAD and Input Power for Thinfilm.Can someone help?Below are the programming the the solar data fiel that you need.
Message 32 of 46
(755 Views)
Here's a quick draft. You still need to deal with the odd parts near the end of the array, but this should get you started.
Message 33 of 46
(746 Views)
u mean the array at spread sheet string to array?
Message 34 of 46
(743 Views)
That's not even a complete sentence! What post are you referring to and what is the question?
Message 35 of 46
(740 Views)
@altenbach ur post what u mean by dealing with odd parts at the array?
Message 36 of 46
(736 Views)
Near the end of the file, there is a new file segment starting with a line containing "Info;Time". The remaining parts should probably be excluded from the analysis, because they are all zero and might not be related to the data from the middle segment.
Message 37 of 46
(732 Views)
@ altenbach yup sorry i know i need help on removing the column of zeros from the array
Message 38 of 46
(727 Views)
@altenbach can also ask how do i create the three rows of heading as seen in the picture create heading for array 1 like Uhrzeit for row 1, row 2 and start row 3.In  the picture for create heading for array 2 the three rows of heading are not there can help?
Message 39 of 46
(726 Views)
It's all there, you simply need to get a few more lines from the header array. Right?
Here's a quick example.
Message 40 of 46
(717 Views)
