06-06-2012 08:37 PM
the "Objective" picture is what i need to get at the front panel but from what u can see from the "Current" picture i only got the rows at the array i need to get the rows and columns at the array which is shown at the "Objective" picture
06-06-2012 08:40 PM
Place an empty array constant on the diagram. Place a string constant inside of the array constant. Since you need a 2D array, right click on the array index terminal and select Add Dimention. You will then have a 2D string array to wire into the array type terminal.
06-06-2012 08:48 PM
is this correct?
06-06-2012 08:52 PM
Does not look lik an array, so no, it is incorrect.
Please crop your images to the intersting part!
06-06-2012 08:52 PM
Does it work for you?
(Please don't make such large screenshots with so much empty space. Cleanup the image in Paint. Or better yet, use the Code Capture Tool.)
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
06-06-2012 08:57 PM
alright thanks can i ask if there is such a thing called"DBL Numeric Constant cos i can only find "Numeric Constant"?
06-06-2012 08:59 PM
Drop the numeric constant, then right click. Representation, then Double.
06-06-2012 09:01 PM
You can right-click any numeric constant and pick the desired representation, e.g. dbl.
06-07-2012 04:44 AM
i solved my problem for my array part but after that i need to generate the results for IRAD and Input Power for Thinfilm.Can u guys help me take a look at my block diagram to see what i have done wrong?Below is my programming file.
06-07-2012 08:33 AM - edited 06-07-2012 08:35 AM
