06-09-2015 03:59 AM
Well in Labview, I can create a 2D array just fine. But I am having trouble building a 3D array. Is there a means of doing this through the Front Panel like one would go about creating a 2d Array? Or can I use the Build Array Function to do this?
06-09-2015 04:08 AM
Hi ShogunOrta,
You can create 3D array using front panel or use build array to create 3D array.
1. Using front panel
Drag down the indexer of an array to have 3 indexer. This is similar to when you create 2D array
2. Use build array
You can use build array to create 3D array by input 2 2D array to a build array function
TuiTui
06-09-2015 04:29 AM
You can also use the Initialize Array function to create the N dimension array of your choice by expanding the 'dimension size' terminal of this function.
06-09-2015 04:56 AM
Thanks Tui Tui and Parthabe. I've tried all those options and they all work. I don't know. In terms of creating it right on the Front Panel, I think I had a brain fart. It's so easy! But again, thanks.
