06-18-2012 07:03 AM
What is that you cannot obtain? And what code? The exec file?
12-08-2012 12:45 PM
I have similar problem.
My project is working perfectly in Labview. There is a invoke node to open and close another VI from which I collect properties for COM ports and save them into XML file. After I build an aplication from this and then run the exe file, the application works fine until I click on button which calls another VI. Then everything freezes. I have to close the app.
I changed absolute paths with relative ones, but it wasn't better. VI which the application calls was set to be Always included in build properties.
I have no clue what to to to fix that.
Thank you for any help.
12-10-2012 07:24 AM
Have you tried the solution in this thread?
12-10-2012 09:00 AM
yes.
12-10-2012 09:12 AM
Post the code that opens the VI.
12-10-2012 09:16 AM
Have you varified it's location? Is it placed where you expect it to be (Source File Settings)?
12-10-2012 09:23 AM
in source file settings I put it in ALWAYS INCLUDED, because I have read before that if you call a vi with invoke node you have to do this.
12-10-2012 09:29 AM - edited 12-10-2012 09:31 AM
Yes. But can you attach your code that is calling the VI?
What I mean by my ealier post is, doule-check your setting in Source File Setting and make sure it is pointing to the correct location (data folder).
12-10-2012 09:31 AM
tomorow, I am allready at home right now 🙂
12-11-2012 01:14 AM
this is how i open the vi.
