Bug in Interpolate 1D for repeated X values?
Using this vi:   LabVIEW 2014:vi.lib:gmath:interp.llb:Interpolate 1D
If you have the (X,Y) points (100,1)(100,2)(200,3)(200,4) and you want to interpolate to find a value for X=150, you would expect (hope?!) to get the answer 2.5. However, the VI returns an answer of 2, since it only uses one (probably the second?) of the repeated values…
The attached VI illustrates the behaviour, and also a workaround, making the X values ever-so-slightly different, to force the Interpolate 1D to give the correct(?!) answer
Message 1 of 9
(3,404 Views)
Oh- and I do have a bug report in for this:   (Reference#7446701)
Message 2 of 9
(3,401 Views)
Why not use the tools from the array palette?
(Of course the FOR loop is not needed for a single interpolation value, just tring to duplicate your setup)
Message 3 of 9
(3,392 Views)
Well... umm... errr... Yep.. That works... 😉
I didn't know (or had forgotten) Interpolate 1D Array (one of my favourite VIs) did that..! Do now, reading the help..!
But... it's perhaps not very well behaved if you reverse the Xs...
And... I don't think that solution works for my full use case, where I was expecting (obviously incorrectly) Interpolate 1D to perform a linear fit through all the data I gave it- not silently ignore repeated points- before interpolating an output.
I guess, describing it like that, I ought just use a linear fit 😉 Interpolate 1D only "joins the dots"- it's perhaps just a little unclear which dots it's going to use...
Message 4 of 9
(3,373 Views)
The 1D interpolation expects an array with increasing values. Also if the first value in the array is greater than the threshold, it gets lost.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 9
(3,368 Views)
Exactly, so while Altenbach's reply was indeed correct for the example data, it is not robust 😉
Message 6 of 9
(3,365 Views)
It's not a matter of robustness. It's a matter of you have to be smart about what you do. It's a poor workman who blames his tools.
Mike...
LabVIEW Champion
Message 7 of 9
(3,349 Views)
Just to clarify here, the Interploate 1D Array function just needs an increasing X value.  The Y values do not need to be sorted at all.  And it performs a linear interpolation between two points surounding the fractional index.
GCentral
Message 8 of 9
(3,323 Views)
Workarounds- and the wrapping required to make them robust- notwithstanding, do we think it's a bug that Interpolate 1D appears to use only the first of any repeated X values? If it is intended to be simple "join the dots" interpolation, should it not at least use data in the order it appears at its inputs...?
Meanwhile, I will replace my use of it with a proper linear fit between my two clumps of data, as I should have done all along... 😉
Message 9 of 9
(3,289 Views)
