12-13-2010 06:24 AM
Howdy
This is a small thing, but I was wondering if it would be considered a bug?
When I drag and drop from the disk hierarchy, into a Project, the folder order gets reversed.
My expectation would be that it would be arranged alphabetically.
Cheers
-JG
12-13-2010 06:39 AM
JG,
i cannot reproduce this using LV 2010 and Win 7 (all english). But i do not have any folder in source control, so this might be one additional difference.
One guess: The folders are added in reverse order of selection. So if you select the folders "bottom up", it might be in the "correct" (alphabetical) order.
Norbert
12-13-2010 07:25 AM
Why bother? Just arrange by name 🙂
Btw. as u might see, I prefer to have auto-populating folders.
greetings
12-13-2010 07:33 AM
Because its an extra step that I would like to eliminate 🙂
Like I said - it's a small thing.
Thats cool, but I do not use Auto-Populating folders. The paradigm does not make sense for Libraries or Classes. I want to keep the directory structure as flat as possible for SCC reasons. But I want the flexibility to structure a Module using virtual folders.
12-13-2010 07:37 AM
@Norbert B wrote:
JG,
Norbert
Thanks Norbert
Here is video of what I see (where selection order does not matter).
Sorry I should have mentioned - I am using Win 7 Ultimate and LabVIEW 2009.SP1.
Cheers
-JG
12-14-2010 05:19 PM
I have reported this as a bug under CAR# 278149. As pointed out in this forum, a simple work around is to manually change the order, or upgrade to LabVIEW 2010.
Brandon Treece
12-14-2010 07:06 PM
If its fixed in LabVIEW 2010 then there is no point worrying about it.
I couldn't check when posting.
-JG
