Bug? Changing autogrow setting of tabs warps the label
  • Place a tab control and resize as needed.
  • Right-click advanced...toggle autogrow setting.
  • Observe:  the label of the tab structure is moved down and far away by a distance of about the height of the tab structure.
Tried in 2012, 2013, 2014. Same result. This is unexpected. Often, the label will move out of the visible FP area, making it hard to find later.
The label position should not change if the autogrow setting is toggled!
(3,281 Views)
Hello altenbach,
Thank you for bringing this issue to our attention! A Corrective Action Request has been filed (#164269) and R&D is aware of the issue.
Nadine H.
(3,200 Views)
