09-27-2007 09:48 AM
09-27-2007 10:15 AM
01-20-2010 01:48 PM
Dear Dave,
I wanted to know if you could provide a copy of the your labview VI? I plan to have a student put together a system to control a Brookfield CAP 2000+ viscometer for my teaching lab. As they are working on it, I can have them look this anomaly...
I have seen issues with Labview where, on the front panel, the thermocouple readings would drop to zero and then go back to the real value, but you didn't see problems when looking at the raw data.
When I had a Ohaus scale connected via a serial port, I saw the values every once in a while go to zero on the front panel, and this would be seen in the data. I think it's a software issue, not hardware...
Take care!!!
Wilson Terrell Jr.
Associate Professor
Dept. of Engineering Science
Trinity University, San Antonio
05-07-2010 04:41 PM
I made this program to get data from two viscometers.
I have done a new version, but i have in the office computer.
Best
CPalha
12-05-2011 09:45 AM - edited 12-05-2011 09:47 AM
Hi all,
I am a new user of labview and I have to make a program to see the viscosity from Brookfield viscometer DVII+. I have tried your program cpalha but I have always a timeout error. What can be my error?
Thanks in advance,
Suneitos
12-05-2011 10:57 AM
Dear Suneitos
Did you configure the time for print interval in viscometer? How much is it?
If it is 30 secounds for example in the labview program you must input in printinterval window 30000 ms.
Another tip is in the windows at top right I think has 10000 it is related with port COM configurations.
What COM port are you using? What the configurations?
You need to see it. Ask for help if you want again.
Best
CPalha
12-06-2011 05:06 AM
Dear CPalha,
Thank you for your quick answer. I have checked the timeout and set it at 10sec. Now i have error 1073807343 : what is your IVI drivers configuration? (cf: http://digital.ni.com/public.nsf/allkb/8130049893D6461E86256F3B00461E1B)
I use COM1 with the configuration in attached file.
Suneitos
12-07-2011 08:20 AM
Suneitos
Did you see what COM port configuration you have in the Brookfield menu? Must be the same has in the computer.
Do you use a rs232 ubs converter? What COM port the computer named it? Normally the computer attributes COM port 12, or 13 or 14 for this cables.
Best
CPalha
12-08-2011 04:37 AM
My configuration was good. the only problem was that i had no procedure to follow and i didn't know how to send data from the viscometer to the computer. Now it's OK, I had just to press for 3sec the button "Print". I believed that it was just for the parralel port. 2 days to find this tip. 🙂
Thank you for your help.
Suneitos
12-08-2011 04:19 PM
Dave,
So this incorrect data only occurs in a single, isolated transmission; then the following transmissions are correct until the isolated incident briefly occurs again, correct?
Is there any way you can post the code in which you are seeing this incorrect data? Off the top of my head I can't imagine what might be causing the issue. My initial reaction was that this may be similar to problems encountered when trying to implement software handshaking using binary data transmission. But this would typically cause a data transmission failure entirely, not send incorrect data. Have you tried using the VISA examples that ship with LV? You would probably have to modify them a bit, but creating a very basic program with minimal functionality might help eliminate the possibility that it is a problem with your code.
Chris G
