02-13-2014 03:54 PM
When selecting "Properties"in the contextual menu of a Boolean control, the following window opens:
Notice the location of the "Show Boolean Text" checkbox.
It might be intended, but I doubt so.
Solved! Go to Solution.
02-13-2014 05:37 PM
02-13-2014 06:05 PM
I think it is where it was intended to be but the label background should not be transparent.
02-13-2014 06:30 PM
I feel so 20th century, esthetically speaking, reading these comments...
02-13-2014 07:47 PM
Do not confuse 'intended' with 'desired' or even 'standard'. On my phone it was hard to see the group box line extending beneath the label. But yes, it seems the intention was to create a set of dependent controls with the Checkbox.
It would be standard behavior if the caption text box was always enabled and entering text would automagically click the visible box. Same for the label.
I do not think it is necessary for the visible check box to disable the other controls.
02-13-2014 08:46 PM - edited 02-13-2014 08:47 PM
It looks a bit different to me on my Win7 computer.
I do believe the checkbox is supposed to be over the line since it is a header for that group box. I don't think you are supposed to see the line through the text. On my Win7 PC, the line doesn't show up behind the text. What I do find weird is that the checkbox text looks bolder than it should, and looks bolder than it looks on yours.
I'll have to look at this on my XP machine when I get a chance.
02-13-2014 09:01 PM
Question, which control palette is the control in the original post from? Classic? Modern? Silver?
02-17-2014 12:35 PM
Silver, but that occurs for all styles.
02-17-2014 12:52 PM
What version of LabVIEW are you using?
Here is my property dialog for a silver boolean withing LV 2012 (the Win7 image earlier was also LV12). I don't see the line behind the text.
Okay. I'd attach the .png file that shows this, but the forums are giving me the "The contents of the attachment doesn't match its file type" error. I haven't seen this one in a long time.
02-17-2014 01:29 PM
LabVIEW 13.0f2 (32-bit)
