06-26-2015 08:56 AM
I believe bookmarking was a great idea, but I was unable to use it in my current project.
My project is large and has been in development since LabVIEW 8.2, and I am now running 2014SP1 (I had the same issue with 2013). Everytime I launch the Bookmark Manager, its window opens up, searching starts ("Populating list... Please wait"), but it systematically crashes, along with LabVIEW, before showing results.
The info I get from LV Crash communicator is :
Exception : Access violation (0xC0000005) à EIP=0x0131833A
Version : 14.0.1 (32-bit)
Possible Cause: C:\Program Files (x86)\National Instruments\LabVIEW 2014\resource\dialog\BookmarkManager\managers\Default\support\BMark_Get Bookmarks for VI.vi
If I run the Bookmark Manager in other projects, it works fine.
Has anybody met (and maybe solved) the same?
Any clue how to solve it?
Thanks in advance.
Solved! Go to Solution.
06-29-2015 05:29 PM
From the screenshot you provided, and report id listed, it does not appear that you have filed a crash report. I would encourage you to submit a crash report the next time this crash occurs.
06-30-2015 08:04 AM
In fact I did it probably a dozen times before, about every time I tried the feature.
Would it help if I provoke the crash once again and send out the report?
06-30-2015 08:53 AM
If you have already sent in crash reports, that is probably good enough. I did find a short help page about using Bookmark Manager with a few tips to avoid errors.
http://zone.ni.com/reference/en-XX/help/371361K-01/lvdialog/bkmk_manager_moreinfo/
Hope this helps.
06-30-2015 09:43 AM
Hope this helps.
Just about what I was thinking... a missing or corrupt BD in the project.
Try: Opening some of the higher level vis in the main application instance (with the .lvproj closed) and launching the Bookmark manager to isolate the offending vi(s)
06-30-2015 02:50 PM
Mass compiling the whole project (and not only the main application and subvis) showed that it needed a major cleanup, which I took the time to do. It allowed the Bookmark Manager to work again.
Thank you and Jeff·Þ·Bohrer for your help!
06-30-2015 03:17 PM - edited 06-30-2015 03:18 PM
Those .lvproj' file can "Get to be a mess" Been there - done that
Keep that "dependancies" clean!
Glad to have helped!
