03-26-2008 12:14 PM
03-27-2008 03:41 AM
Hi Rob,
Regarding to this issue, i had to drop the Bluetooth and switch it to WIFI.
Is it possible for me to connect two PDA via WIFI?
If so can you give me some hint on the setting for it?
Thanks.
03-27-2008 03:54 AM
Hi Wyatt,
I'd recommend linking your PDA upto the PC via WiFi either via Ad-Hoc (directly) or through a router, and try and TCP Simple examples to ensure you get throughput and both devices can see each other.
All the best,
03-27-2008 04:09 AM
03-27-2008 04:19 AM
You can do it 2 ways,
1. Ad Hoc which is connect the PDA to the Laptop Directly
2. Have the PDA and Laptop connected via a router
Both outcomes will require you to know the IP of the PDA and Laptop but will work equally well, once the wi-fi link is up and running the examples will show you how to architect the wireless in LabVIEW (Server and Client). As you've moved from Bluetooth to WiFi I'd suggest starting a new post with a relevant title for any future questions on this - that way people can find it and answer you better under the forums.
All the best,
03-27-2008 04:22 AM
06-30-2008 01:45 PM
06-30-2008 02:07 PM - edited 06-30-2008 02:11 PM
08-25-2009 08:55 AM
I'm from Brazil
Bom dia Bob, tenho erro semelhante(BT10022) no PDA, eu consigo executar o PC mas no PDA o cliente não executa. Tenho Smartphone com WinCE 5.0, qual drive tenho que instalar no mesmo para poder ser reconhecido pelo Servidor(PC)?
08-25-2009 08:56 AM
I'm from Brazil
Helton Castanheira
Brasil - Belém PA
