07-02-2014 09:55 PM
I installed LabVIEW for my MOOC on Modelling and after I restarted computer I got blue screen of death because of page fault in nischifk.sys.
OS: Windows 8
What could be ways to fix the problem? I am ready to uninstall LabView if necessary.
07-02-2014 11:17 PM
No before uninstalling talk to NI guys..There might be some compatibility issue
07-03-2014 12:44 AM
They don't accept my ticket because I do not have commercial licence (it was for MOOC). NI site said use forums. That is what I did.
Do you know any way to push this to attention of NI guys?
07-03-2014 01:06 AM
You can try to reboot the system in safemode and try to restore the PC and then repair LabVIEW or re-install. If you are using it for learning purpose and if you don't use hardware, then don't install device drivers.
07-03-2014 02:23 AM
You can send main to suport team. They should surely help you. Talk to them in phone.
During installing you received any error or something?
07-03-2014 10:52 AM
So, nobody experienced this problem?
07-03-2014 12:51 PM
07-03-2014 02:09 PM
Thank you guys. The problem is fixed. It was due to bad driver.
07-03-2014 10:18 PM
Please explain how you fixed it and what was the problem and mark that as a solution, it will be really helpful for others who get similar issue.
07-08-2014 05:29 PM - edited 07-08-2014 05:29 PM
I just hit this exact same issue on our Dell Precision R7610 rack-mount servers, see attached BSOD screenshot. It happened immediately after I upgraded to NI-RIO to 13.1.0.f1 . This is repeatable with 3 of 3 of our Dell servers and I will be putting in a call right now to NI support to see how to fix this issue. I will follow up with what they say so others can benefit if they too hit this problem.
