11-13-2015 04:10 AM
Hello
i have the Biomedical toolkit listed on NI license manager and appears to be activated but it's not showing up in lab view
how can i solve this problem ?
11-16-2015 08:42 AM - edited 11-16-2015 08:43 AM
Hi laythrzraiqat,
Thank you for posting on the forums. Have you tried using quick drop (control + space) to search for the biomedical toolkit VIs? Here is a link of all the VIs: http://zone.ni.com/reference/en-XX/help/373696B-01/lvbiomed/bio_vis/
If you have and you still can't see them, can you let me know which version of LabVIEW, the Biomedical Toolkit, and DAQmx you are using.
11-16-2015 04:24 PM
Still nothing showing up , im using LabView 2013 ( 32 bit ) V13.0
11-17-2015 09:26 AM
Hi laythzraiqat,
If you open the NI License Manager, you should see a shaded box next to the Biomedical Toolkit (under Toolkits). If this box is green, the toolkit is fully activated. If it is shaded yellow, it is not activated and you should right click and hit activate.
Let me know how this works out for you.
12-18-2015 01:53 AM
I am having the same issue, the toolkits for biomedical does not get activated in evaluation version. How to add the biomedical vi in palette. Kindly help provide soln- asap.
Sharmila
12-21-2015 08:55 AM
Hi Sharmi91la,
I recommend you try the same thing that I suggested to laythzraiqat above. Navigate to the NI License Manager and you should see a shaded box next to the Biomedical Toolkit (under Toolkits). If this box is green, the toolkit is fully activated. If it is shaded yellow, it is not activated and you should right click and hit activate.
05-17-2016 08:42 AM
Hi, I am running into similar issue. I am using LabVIEW 2011 and have installed biomedical tollkit v2012. I tried to activate Biomedical toolkit from NI License Manager but it asks for serial key. Where can I find a serial key for Biomedical toolkit v2012? Do I need to buy this toolkit or is it a free software?
Thank you
07-01-2016 09:15 AM
You have to have the advanced signal processing toolkit to activate the Biomedical Toolkit.
If you have that and you still can't activate it, you can call NI Support to have them generate a code for you.
-Ben
