Binning issues with Apogee camera
 I am using labview to interface to an Apogee 32ME camera.
 I use Automaton open and use Icamera methods to set the exposure and obtain images and it works fine.
 But the moment I set any binning, it gives an unspecified error when I call the "Expose" method (that is when I am trying to expose the camera). I am not sure why this is so. Any help would be appreciated. I am posting the code along with this email.
 Thanks for your help!
Cheers,
 Bala
(3,545 Views)
All I had to do was to set the NumX and NumY values to suitably reflect the binning. The camera is not smart enough to set these values itself.
I am leaving this thread for future references...
Cheers,
 Bala
(3,543 Views)
Glad to hear you solved the problem, and thanks for posting - the next person to have this problem will hopefully find the solution here!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,528 Views)
I am having similar issues of binning. I am trying program an Apogee KX260e model using LabVIEW. I can use Automaton open and use Icamera methods to set the exposure and obtain images and it works fine.
But like Bala said, when I try to bin the image to improve capture rate using the bin x and bin y commands, expose the image and then convert the variant to data, I get an error message. I would appreciate any help and a sample code if possible.
Thanks.
Edwin
(3,045 Views)
Hi Bala
 I am using labview to interface to an Apogee U2 camera
 I use Icamera methods to set the exposure and obtain images and it works fine.
 But the moment I set any binning  and I have some problem,It take image very fast and the images not as well as before.
(2,448 Views)
