12-28-2010 10:48 AM
I used quite number of loops on FPGA and need to transfer single point datas between loops. Only the current value of data is needed so buffer is not necessary. I don't want use target scope FIFO since it require minimum 21 elements and I only need the current value. Is there other way other than local variables?
Thanks for help!
Tom
12-28-2010 10:57 AM
12-28-2010 11:30 AM
All loops use same clock. Some are singe cycled timed loop (SCTL) and others are timed while loops.
Not particular. Just would like to explore other methods if possible.
Delay is not a problem. I say buffer is not necessary because I only need the current data value
Thanks!
Tom
12-28-2010 11:50 AM
Thanks for the details. In the case you describe I have only used Locals to move data between Single Cycle Timed Loops (SCTL), but a global should work as well. Note: Locals will insert a flip-flop in the path.
One thought about moving data between SCTL and While Loops - since the While loop may take several FPGA clock cycles to complete an iteration, you should make sure data from an SCTL is constant/present long enough for the While loop to see it. This may require additional handshaking logic between the SCTL and the While Loop.
12-28-2010 11:58 AM
A memory block is another fine way to transfer data between loops on an FPGA, so long as those loops all run in the same clock domain.
12-28-2010 12:36 PM
I think memory block is good to transfer array of data. For single point data it could be overkill?
12-28-2010 12:44 PM
Depends what you mean by overkill. There is a minimum amount of memory used per block, so if you need to transfer a lot of individual points of data it would not be efficient to create a separate memory item for each point. However, if you only need to transfer a few data points and you don't need that memory for anything else, the memory block is a reasonable choice.
06-30-2014 10:12 PM
Hi RyanB,
You make a note of "local variable" that "Local will a flip-flop in the path".
May I ask more questions about this point ?
First, there must be one flip-flop or register corresponding to a "control (or indicator) " with
additional logic and I denote the output of this flip-flop by the letter "Q".
Suppose I use a local variable to access the control (or indicator), and I denote the access
point by the letter "A" .
Will an additional flip-flop be implemented between path QA and the output of this additional
flip-flop will be connected to point "A" when compiling the LabVIEW FPGA code?
Dose LabVIEW FPGA use the same way when the local variable is in another clock domain?
If so, how to ensure data coherency and avoid the problem arising from metastablility?
Thanks for your help.
Godel
07-01-2014 12:08 PM
Hi Godel,
Since this discussion thread is over 3 years old, it would be better to start a new thread with your specific questions to get quicker help.
I did a bit of research on your question, and found this helpful White Paper (http://www.ni.com/white-paper/7727/en/) that discusses the resources used for components in LV FPGA code. For local variables (although it depends on hardware), it looks like it uses Flip-flops and LUTs.
As for using local variables with different clock rates, I found this KnowledgeBase article that might help shed some light on your question - some issues can arise from using them with more than one clock rate (http://digital.ni.com/public.nsf/allkb/C683585460E88508862570D1006B7434)
Hope this helps! Again, if you have follow-up questions, I would definitely recommend creating a new thread
