04-21-2016 11:20 AM
Hi all,
Relatively new to OOP still and have been working on an OOP project. My basic architecture is an OOP state machine, each class represents a different test. I have one test that will run through all the tests, so i figured i could just pass a new class into a for loop and have it run through all the tests. Problem with that of course is i connect to a device and the resource is lost with every new object. One solution ive come up with for this problem is to have a class that composes of the test class and the device resource and i could bundle a new class every time i switched tests and carry the same resource on the wire.
Any comments welcome, if my overall plan for this program is off please say so.
Thank you,
Matt
04-21-2016 11:54 AM
Use a shift register to store your device and have each of your Run Test methods have an input for the device object. You will probably need a couple of tests for Initialize Device and Close Device. These should be the only two cases that open or close your device. So no composition is needed.
04-21-2016 11:59 AM
Hi Crossrulz,
That actually makes a lot of sense, i was hoping to be able to carry it on the same wire as the class, but i think it probably just makes more sense to have it in the for loop. I suppose i should have one parent method for configure and open device and one for close device, beofre and after the loop?
Matt
04-21-2016 12:22 PM
matt198717 wrote: I suppose i should have one parent method for configure and open device and one for close device, beofre and after the loop?
That would make sense to me.
