Beginner - How to find Y value if I have only X value?
In my application there are waveform chart and a XY graph. When I click over a graph, I get the X value. But I want to know the value of Y for that X value in another graph. Is it possible? How?
I am using labview 8.2
Thank you in advance!
Message Edited by Oliveira on 05-10-2007 03:45 PM
(4,175 Views)
what do you mean by "When I click over a graph, I get the X value"? Do you use the cursor value? the mouse position?
(4,158 Views)
I use the '"WaveForm Chart:" Mouse Down' event to do it.
So, I connect the "Coords" property to "MapCoords to XY" method.
After, getting the value of X, I want to know the value of Y in another graph, using the X that I got before.
Thank you in advance.
(4,129 Views)
If both Graphs use the same X value, you can simply Index the Array of Y values with your newly discovered X value.  If the graphs were plotted with different X scales you will have to use the "Interpolate 1D array" and "Threshold" Vi's to look up the value of X within the other graphs array of x values to find its index.  Then use that index to pick out the Y value.
Craig
LabVIEW 2012
(4,119 Views)
I understood what you explained, but I don't know how to code it.
Could you help me?
(4,106 Views)
Have a look at the Attached vi.  It should be a starting point for you 🙂
Craig
LabVIEW 2012
(4,101 Views)
In fact try this one (It has some default values in it, arent i kind to you :))
LabVIEW 2012
(4,098 Views)
