06-29-2016 01:34 PM
You can use an Or node to perform an OR operation on your boolean that you write to the Stop terminal. Make the OR condition True if trigger is True, or True if total # samples has reached 10k (or you can base it on the number of iterations, or a timer, or many other things).
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
06-29-2016 01:35 PM
So simple it might just work -- I'll let you know
Thanks!
06-29-2016 01:37 PM - edited 06-29-2016 01:38 PM
Here's what I mean.
Cheers
