07-05-2016 03:53 PM
I need to put together some labview software on my current computer and run it on a different computer in a different country in a month. I've been told the computer that I will eventually be running on abroad has Labiew 2013 SP1. I do not have Labview on my current computer and figured I would install the same 2013 SP1 version ito ensure compatibility. However, it appears this is not an option. When I go to download products my options are 2012, 2012 SP1, 2014 SP1, 2015, and 2015 SP1.
So what is the best move here? Can I install 2015 SP1 and expect everything to work ok when I go abroad? I'm assuming not. Why is 2013 SP1 not an option for me? Do I need to see if the guys abroad can update to the latest version? What if they cannot?
Thank you,
Trevor
Solved! Go to Solution.
07-05-2016 04:00 PM
I have trouble believing that you are not allowed to install LabVIEW 2013. The search engine is kind of dumb. Try being more specific when searching for the download. I just did a search for "LabVIEW 2013 SP1" under the "Product Downloads" section and managed to find it there.
07-05-2016 04:35 PM
Thanks for the prompt reply. I see what you're talking about. I was looking under the quick link to Labview downloads. When I do the search you are talking about I only see indivual modules...FPGA, Realtime, vision, softmotion, NXT, etc. Shouldn't there just be an all included download?
Also if I was to download the latest version, would the software I create run in 2013 SP1, or would I encounter issues?
07-05-2016 05:27 PM
Search request in Downloads
LabVIEW 2013 SP1 32 bit -patch -Run-Time
The first link is required download
http://www.ni.com/download/labview-development-system-2013-sp1/4527/en/
Generally saving back for previous version works good, but I did not try it on large project.
07-06-2016 12:35 AM
Like the others said, the best option is to get the same version. If for some reason you really can't, I would suggest getting an older version, because while you can write the code in a newer version and backsave, there are at least two issues which can bite you if you're not well aware of how they work:
This doesn't happen if you use an older version, because the newer version will simply open it.
07-06-2016 08:06 AM
How come when I follow this link there is no available download? It prompts me to register a serial number (attached screen shot). I've registered a serial number provided by the university but still have no download options.
07-06-2016 12:03 PM
Are you logged into NI.com when you went to this page?
07-06-2016 12:10 PM
Yes I am. I double checked to confirm (attached images shows I am logged in).
07-06-2016 12:14 PM
Okay. That's good.
Next thing is to click the link that says "register your serial number to access previous versions".
07-06-2016 12:18 PM
Right. So I've done that. And under products it already displays my academic site license. there is a drop down menu next to this license that has the option to download past versions. I have followed this and been unable to find 2013 sp1
