BUG: Split then join reverses byte order - sometimes
I was creating a simple VI to serialize an I32 array to bytes and ran into this interesting bug. This code is being run in 32bit LabVIEW 2014 SP1, fully patched. Save the two attachments and run TestI32ToByteArray.vi. Note that the 6 and 7 at the end of the array are reversed. If you probe around, the data all looks good, except the split string on the final low word is reversed. Any ideas?
More details on setup:
LabVIEW 2014 SP1 32-bit
AMD FX-6300 3.5GHz hex core processor
Windows 7 64-bit, fully patched
8GB RAM
the entity formerly known as DFGray
(2,871 Views)
Accepted by topic author ShadesOfGray
Check your wiring, the 6 is wired to the bottom terminal of the join, and the 7 is wired to the top.
(2,864 Views)
<edit>I lost the race to Hooovahh<\edit>
Jim
(2,861 Views)
Wuah haha Smiley Wink
(2,849 Views)
I obviously need to drink more coffee (or less Smiley Frustrated ).
(2,836 Views)
