10-20-2014 03:25 AM
I'm using a set-up where I control a servo with Labview. I run the VI, set some speeds to the servo, and within minutes, Windows gets a BSOD. I would like to know the cause of the problem and a fix please.
What am I using?
- Windows 8.1 (and windows XP before)
- Labview Student Ed 2014
- NI Visa
- NI Daq mx
- USB to RS-485/422/232 Converter
- Nanotec servo
- Nanotec Labview example: http://en.nanotec.com/support/application-notes/labview-example/
What happens?
I open the VI, set the com port. Run the VI and set some motor speeds. Within minutes windows 8.1 gives a Blue Screen, with the error MULTIPLE_IRP_COMPLETE_REQUESTS. In Windows XP, this gave the error IRQL_NOT_LESS_OR_EQUAL. After rebooting, windows 8.1 shows Automatic Repair. 'Automatic repair couldn't repair your PC', and refers to C:\WINDOWS\system32\Logfiles\Srt\SrtTrail.txt.
This is 'Startup Repair diagnosis and repair log'. This gives some actions that take 0ms, untill finally:
Boot critical file c:\windows\system32\drivers\nipbcfk.sys is corrupt.
Repair action: File repair
Result: Failed. Error code = 0x2
Time taken = 8546 ms
Opening that file in notepad shows this: http://pastebin.com/dwp2X5er
Can anyone spot why Windows goes into a BSOD, and how this can be prevented?
10-20-2014 08:35 AM
It sounds like the installation of some NI drivers failed on your system. Can you please re-install those? I recommend to uninstall the current installed ones first.
Also, please try to install the latest driver versions. If you are using old drivers (e.g. from an out-dated driver DVD), it is possible that you have drivers installed which were never tested with Windows 8.1.
Norbert
10-20-2014 09:45 AM
