09-24-2012 10:05 AM - edited 09-24-2012 10:08 AM
Returning the outer loop resutls in two rows of data which I am struggling to classify. Please see the attached
09-24-2012 10:11 AM
Please attach your code so we can see what you are doing.
09-24-2012 12:47 PM
Here it is crossrulz. Thank you for your help.
09-24-2012 12:47 PM - edited 09-24-2012 12:48 PM
Sorry for the duplication in my reply
09-24-2012 02:37 PM
Still waiting for it to be solved. Any idea?
09-24-2012 02:43 PM
I still don't know what you want.
What is the meaning of "classified"? Since the x y data contains much more points than the averaged x y data, I still don't see how you want to squeeze it all into four columns.
09-24-2012 03:01 PM - edited 09-24-2012 03:07 PM
Hi Altenbach,
Based on my experience, in some occasion you need to see the data of individual loop without averaging in case something wrong happened to any of the loops during the operation (although the averaging in most cases would be desirable) . And also to compare the behavior of one loop with the averaged one. So, the data come to me with this code is hard for me to extract the information that I am looking for.
So, I would like to have the data to be separated into four columns and saved to text file as I mentioned in my previous posts.
You are right that X and Y points will be more than the averaged points but that should not be a problem. The excel file at the end should contain the following information:
IN col. X Col Y Average X Average Y
N* 250 points N* 250 points only 250 poins 250 points
09-25-2012 07:02 AM
So you really want 2*N+2 colums and 250 rows?
09-25-2012 08:45 AM - edited 09-25-2012 08:45 AM
Hi Crossrulz,
If I set the outer loop to 3 (no. of loops), and assuming that the inner loop would give only 2 measurement points, the data file should has the following data (just for example I use arbitrary numbers which may be generated by the random number generator)
col. (1) col (2) Col. (3) col. (4)
X Y ave (X) ave (Y)
0.1 0.3 (0.1+0.2+0.4)/3 (0.3+0.5+0.8)/3
0.2 0.4 (0.2+0.3+0.5)/3 (0.4+0.7+0.2)/3
0.2 0.5
0.3 0.7
0.4 0.8
0.5 0.2
Hope that expalins what I mean.
09-25-2012 10:47 AM - edited 09-25-2012 11:38 AM
Thanks. It really wasn't clear at all before. Try something like this....
(EDIT: corrected mistake, please re-download attachment, now saved in LabVIEW 2010)
