04-22-2009 03:11 PM
I haven't done any LabVIEW coding for sometime so I'm at a lost as to how to tackle my latest problem. I'm using a cFP-TC-120 to take temperature measurements of a jet air stream. I would like to read from each channel for a specified amount of time and then average the values collected for each channel. So read from channels 0-7 for 5 seconds, average readings for each channel, build array of averaged values.
Thanks in advance.
04-22-2009 03:32 PM
04-22-2009 03:40 PM
I was hoping I wouldn't have to show it, kind of embarrasing lol. I've messed around with a few different options and this is the latest. I stopped early because I could tell the diagram would be a mess which usually means I'm going about things in the wrong direction.
04-22-2009 05:52 PM
04-28-2009 02:51 PM
That's what I needed. Thanks for your prompt help, much appreciated....
06-17-2009 10:52 AM
I have a similar problem to this one. I am reading in data from 4-5 channels and I would like to average the value from each channel. I have LabView 8.5, though, so I could not open the example that was posted.
Attached is a VI that I made for reading in the data from a single channel. I would like to read in the voltage readings from multiple channels and average the values so that I can calculate the corresponding pressures for each channel as I did for this one channel.
Thanks!
06-17-2009 11:22 AM
First time saving for a previous version, hope it works.
06-17-2009 11:49 AM
Thank you! This version did work.
