05-01-2012 04:39 PM
Hi JaymeW,
So I was able to create what you showed. However, the plot legend didn't change. Please see the attached VI.
What am I doing wrong?
05-01-2012 04:41 PM
Forgot to attach the data file
05-02-2012 04:12 PM
Hi murchak,
Sorry for the confusion; the property node that you were using before is the correct one, all you need to do is add that additional property to it. Here is a screenshot (instead of a VI snippet) that is hopefully more clear
Also, be sure that Active Plot is above Error Bar Name because the node executes from top to bottom.
12-13-2014 07:42 AM
THANK YOU.
I am sending my VI.
I am naming plots, by constant parameter different for each plot.
12-13-2014 12:38 PM
Georgesvk wrote:I am naming plots, by constant parameter different for each plot.
This thread is already marked as solved and has not seen activity in years. Why are you posting this???
Your VI uses a format specifier that is invalid in most of the world (using a comma in the numeric specifier ( %,2f instead of %.2f). The plot naming convention also seems quite specialized and not useful for the typical case. Your VI will just confuse.
If you think you have made a universally useful VI that could be of interest to the community, start a new thread and describe in detail why it is useful, show some typical application scenarios, and provide full documentation. It would also help to clean up the code a little bit (logical layout without overlapping wires, add comments, etc.). Also change the connectors so inputs are on the left. Right now you are violating quite a few basic design guidelines.
Thanks!
10-17-2018 01:09 PM - edited 10-17-2018 01:29 PM
Super old thread apologies for dragging it up again, but I was trying to make this method work and thought it would be easier to ask in here than start a new thread with the same basic question. I am trying to auto populate the plot names with an array of strings, and used a similar method, but it always seems to state that the XY graph is not in Edit mode (err 1073) no matter where I put the property node (I have tried putting the write function before the other data is written at the same time, and after)? This is probably a really stupid question but I am stumped.....
Using LV 2011 SP1.
10-17-2018 02:13 PM - edited 10-17-2018 02:15 PM
Hi stew,
Yes! 😄
You are trying to change the label of the graph - this will only work in edit mode as the error message says.
Maybe you should try to change the plot labels instead?
Btw. using AutoCleanup (Ctrl-U) will improve your block diagram as long as you don't follow the style guide…
10-17-2018 03:35 PM
Hah that does make more sense! Thanks!
