11-08-2013 04:44 AM
Hi, I need attach a folder with files created every day in a remote front panel. I've publicated the front panel with web publishing, but I want a download link of a folder.
How can I make it?
11-08-2013 09:09 AM
Maybe writing code in HTML document created?
11-08-2013 12:22 PM
There is no way to have your LabVIEW code create a link within a front panel that will send the web browser somewhere else. If the folder location never changes, then you can create a static link in the HTML document to that location. You could experiment with having your LabVIEW code re-write the file that is being served, but I don't know if that file is continuously read from disk or loaded only once at startup. You could also look into Embedded Server Pages Scripting.
11-08-2013 03:51 PM
Ok, thanks! I'll try it,but I don't know if I can attach a folder in a HTML or just a file.
