06-01-2008 09:50 AM
Threshold
and Input Array
, and one output, Output Array
. Output Array
contains values from Input Array
that are greater than Threshold
. Array Over Threshold.vi
in the C:\Exercises\LabVIEW Basics I
directory. Array Over Threshold VI
to output an array with the values greater than 0.5. Using Array Over Threshold.vi
directory. 06-01-2008 10:02 AM
06-02-2008 08:15 AM
06-02-2008 08:41 AM
URL?
You have a help menu in LabVIEW. Under that help menu is 'Find Examples'. Select it.
06-02-2008 08:41 AM - edited 06-02-2008 08:42 AM
Hi Mbdeck,
here is a picture of one way to solve it. Hope it helps.
Mike
06-02-2008 09:10 AM
Mbdeck,
Even though Mike gave an answer to your homework question, you should still look at the example that comes with LabVIEW.
06-02-2008 09:37 AM
Hi Mike,
I'm not on my computer where I have the labview programme was installed. I think I understand most of your code but I would have prefered the two step process that was described in the problem where you have to build two VIs and use the other as a sub VI. In any case, what is that function in the middle of the For loop with the boolean input called?.
06-02-2008 09:46 AM
Dennis
This is not a homework. I'm just trying to learn this stuff on my own and I'm seeking help because I got stuck. There is no instructor. It is a free online course.
06-02-2008 09:56 AM
06-02-2008 11:07 AM
