03-09-2015 05:34 AM
how to make an array like the attached one and to see it's partitions names in front panel. I mean that if I have 10 bits , I would like to take the 1st 3 bits as the first field and the 2nd 7 bits for the other field or to make it with bytes instead of bits
03-09-2015 05:56 AM
Hi Marina,
you could use ArraySubset to get those different parts of your byte array.
And then you could put these parts into elements of a cluster to make it look like your example image…
You don't have "bits" but most certainly "bytes"!
03-09-2015 06:08 AM
Can you give me an example for it with the labview ?
03-09-2015 06:15 AM
If you don't want to actually seperate the items in the array, the easiest way to accomplish what you want is to simply create an indicator for the array and place labels and rectangles on the front panel for each section. You can find these in the decorations part of the controls tab.
03-09-2015 07:19 AM
can you tell me how to section it by steps please because I don't know labview well. Thank you
03-09-2015 07:31 AM - edited 03-09-2015 07:32 AM
03-09-2015 07:51 AM
Here is a smaller example. You can change it to fit what you want to do. Good luck.
03-09-2015 07:58 AM
If you can't figure out the Array Subset function, you definately should be going through some tutorials, many of which are free.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
03-09-2015 09:55 AM - edited 03-09-2015 10:06 AM
03-09-2015 10:28 AM
Try something like this
