03-03-2014 04:01 PM
I have numbers in the block diagram. 0 2 4 6 are the x coordinates, while 1 3 5 7 are the y coordinates. When I save the x And y coordinates are on the same row, but I want the X coordinates in the first row and the y coordinates in the second row. Is there a way to solve this problem???
03-03-2014 04:12 PM
You need to make your data a 2D array
03-04-2014 01:11 AM
Sorry Omar, can you post the jpeg image. I haven't the last version of LabVIEW.
Thanks for your reply.
03-04-2014 01:41 AM
Hi Mark,
in your VI you create a 1D array of data - and then you wonder why they are saved as one row? Really?
You have to put those values in a 2D array. To do so create 1D arrays for both x and y values and then build a 2D array from those two 1D arrays…
03-04-2014 02:30 AM - edited 03-04-2014 02:31 AM
Here is the screenshot. But thank Omar_II, if you mean that his was useful.
03-04-2014 03:07 AM - edited 03-04-2014 03:08 AM
